Left blinker out
Old Feb 14, 2007 | 02:02 AM
Inev's Avatar
Default Left blinker out
Yup, the topic states it. My left blinker on the headlight is out, and I have no idea on how to go about on this...
[IMG]local://upfiles/17398/A7F647BFD0CC4DC1ABD315B3F939119C.jpg[/IMG]
Old Feb 14, 2007 | 02:32 AM
Stumasters's Avatar
Default RE: Left blinker out
You just need to change the bulb?
If you can't access the bulb from under the hood easily, check the DIY section for a walkthrough on removing the bumper and headlight assembly to swap them out.
Old Feb 14, 2007 | 03:27 AM
importlegends's Avatar
change the bulb[8D]
Old Feb 15, 2007 | 01:22 AM
Inev's Avatar
Okay this might be a little interesting....
Well, when I alarm it.. or lock it via the alarm system, the right blinker only goes off, but when I actually turn on the left blinker it works.. so the bulb is fine.. What is causing this? The wiring?
Old Feb 15, 2007 | 10:46 AM
cderalow's Avatar
does it work with your parking lights on?
if not, I'd think maybe the relay for the parking light is dead/blown?
also, blue/white turn signals are illegal in most places (most states require amber bulbs or lenses)
Old Feb 15, 2007 | 10:56 AM
mxs's Avatar
mxs
it's a 2 filament bulb
one filament is probably blown
replace it first.... if that doesn't work, then come back
Old Feb 25, 2007 | 09:08 PM
Dragon2125's Avatar
I had the problem myself. The running light was out but the turn signal worked fine. Dual filament bulb - just replace the bulb. Although I haven't actually figured out how to do that myself yet. As far as i can tell you have to remove the two nuts holding the headlight cover on first. I can't see another way of doing it unless you have really tiny hands....
ride2clean03
Sep 8, 2011 11:46 AM
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
alos31
Feb 8, 2006 02:10 PM
mmille_mr2
May 26, 2005 05:15 PM
Super Mario
Feb 23, 2005 10:27 AM
