left side speakers not working
Old Sep 13, 2005 | 09:52 AM
baddriver86's Avatar
Default left side speakers not working
well i recently realised that the speakers on the left side werent working and i dont understand why...they just went out all of a sudden...the front and the back doesnt work....i tried the balance and fade on the head unit but when it comes to the left side you dont hear anything...please help
Old Sep 13, 2005 | 11:51 AM
Remmy's Avatar
Default RE: left side speakers not working
It would be great if we knew that it was stock speakers/ h.u or not.
Old Sep 13, 2005 | 06:03 PM
oh sorry bout that...the speakers are stock but the head unit isnt...its a dual something with a 2.5inch monitor built in
Old Sep 14, 2005 | 08:39 AM
Remmy's Avatar
Here are some things to do, check connections, you might as well go ahead and put in new speakers to improve your sound. If that doenst work, it could very well be your head unit and there isnt likely to be a left or right channel fuse thats popped like in the old days. So, you might need a new head unit.
Old Sep 18, 2005 | 04:49 PM
theycallmerickjames's Avatar
dual = ca ca
Old Sep 18, 2005 | 05:39 PM
amg6975's Avatar
If you have access to a digital multi-meter (you can get them really cheap at radio shack or where ever) :
1) Unplug the speakers and test the resistance of them, if you get a reading other than 1(infinate) then you're fine there. If you get an infinate reading then you're speakers are totaly shot, go get new ones.
2) Pull out the reciever, turn it on and test the voltage across the + and - terminal of either speaker right at the back of the unit, if you get a reading(it'll be bouncing all over the place,) your reciever's fine, your wiring is cut or crossed somewhere. If you get no voltage, your reciever's shot, go get a new one.
3) If it's not the speaker or the reciever run new wires to the speakers and it better work, if not... you've got me.
Old Sep 18, 2005 | 06:33 PM
z6 FoRiLLa's Avatar
maybe it's your left ear that's not working, try some q-tips
Old Oct 29, 2023 | 01:42 PM
El Truezon's Avatar
same issue speaker front left doesn't work. cut lines blue and grey black left speaker works with jumper lines but speaker in left front door is red / green red. weird because right front speaker is going out on red/ green red. on radio set to right front only and it works. left only nothing.
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
chrisroug
Oct 2, 2006 11:36 AM
thedougler
Jul 3, 2006 06:01 PM
Exman90
Jun 20, 2006 11:45 AM
JohnJ1974
Mar 24, 2005 01:45 PM
