Lights Keep Burning
Old Jun 9, 2008 | 03:29 PM
HONDA_GUY's Avatar
Default Lights Keep Burning
To many lights are burning out on my car. But it's never the same one, they diddn't all burn out at the same time. One foglight, tail, daytime headlight, brake, 2 interior little buttoms, and on my speedometer it's kinda dull in one place....
I think it might have something to do with my sound system. I'm running 2 amps, a 4 channel that runs my interior speakers, and a mono which runs only one 12".
I recently just installed a capacitor, but i dont know how well this worked since I just discovered today that my brake light ws out.
I dont know if the lights are just old, or if theres something else wrong.
What can I do to fix this?
Thanks
Old Jun 9, 2008 | 07:16 PM
cyberx32's Avatar
Default RE: Lights Keep Burning
Maybe your alternator is messing up?
Old Jun 9, 2008 | 07:29 PM
ORIGINAL: cyberx32
Yeah, possible power surges due to a bad voltage regulator (built into alternator). Take car to AutoZone for free testing of the charging system.
Old Jun 10, 2008 | 07:52 AM
Measure the voltage at the battery with the engine running but everything else turned off. It should not be more than about 14.5 volts. Over 15.5 is definitely a problem.
Old Jun 10, 2008 | 07:48 PM
HONDA_GUY's Avatar
ORIGINAL: mk378
Ok, I will test it tomorrow. If it is over what do I do?
Old Jun 10, 2008 | 07:54 PM
Excessive voltage means you will probably need to replace the alternator, or take the alternator apart and replace the regulator unit in it.
I was also thinking that vibration (e.g. subwoofer) tends to be murder on bulbs.
Old Jun 10, 2008 | 08:05 PM
HONDA_GUY's Avatar
ORIGINAL: mk378
Well before I got my Cap, every time the bass hit the lights would flicker alittle bit. But now that the cap is in it's fine....
Old Jun 12, 2008 | 01:40 PM
HONDA_GUY's Avatar
ORIGINAL: mk378
I tested it, and it's at 14.4
boiler1
Feb 23, 2012 06:14 AM
mrmagic0097
12
Feb 18, 2009 01:45 PM
stylincompact
Jan 2, 2008 05:11 AM
TBon3
Mar 24, 2007 11:58 PM
psychocivic
May 22, 2006 08:23 PM
