need to get wired up
hey guys, want to run my own gauge wires, i mean from the actual sensor to the gauge itself, if you guys have any diagrams you can share that might help, it a 2000 wiring harness
speed, tack, fuel, and oil
thanks ahead of time
yeah sorry, should have given a little more detail,
the motor is out of a 2000 EX which i swaped into a 98 DX, im using my 2000 wiring harness and my 2000 ECU, since 98 is OBDa1 ithink and 2000 is OBDb2 i just want to run my own gauge wires due to the fact the the cluster doesnt work
i think you need more research on what your doing...
also a 2000 is obd2b and your 98 is obd2a
keep all your 98 wire harness and stuff just use the 2000 head and block and get a obd2a vtec ecu and wire up vtec yourself.
what you are saying is your 98 had the d16y7 and you swapped a d16y8 into it
bakertime
Jun 23, 2007 02:48 PM
$200Civic
Apr 23, 2007 01:47 PM
