No rear speakers
I just bought my civic, and the rear speakers aren't puting out any sound, but fronts work fine... what should I look for? And yes, the fade adjustment is in the correct position.
I can't believe how incredibly crappy the stock honda head unit is... no bass output whatsoever. [:'(]
Used, 117k miles... so I'm assuming there's no warranty. I'm going to go mess around with it and see what happens... I'm no dummy when it comes to electronics, I was curiouse if there was a common problem like a certain spot a wire gets pinched or something.
Thanks for the input.
I figured it out. I spent a bunch of time just rifling through the car and found a couple of things, like one of those stupid bass-sensitive neon lights under the dash (which I removed) and a couple of amp wiring kits (which I left in) and I found that the previouse owner had used the rear speaker circuits to power the amps in the truck, so I re-wired them and presto! Now the speakers work...
Thanks for the help everyone.
sandjstickney
Apr 18, 2007 11:01 PM
OCH Orange County Honda
May 25, 2004 08:58 PM
