old security system.
Old May 15, 2008 | 08:45 AM
Try.Fail.Repeat's Avatar
Default old security system.
So I was fiddling around with my car today and discoved the brain for the security system that the previous owner had installed. I always knew that the car had one since I found the horn in the engine bay, but I never knew what brand of system.
It's a Rattler 300 made by DEI
I know the thing is old as all hell and it's no longer hooked up since the wiring harness was disconnected from it.
I don't have the remote for it, but I was trying to decide if it was worth spending $30 on a new remote and reprogramming it to see if it still worked for a temporary security system until I can afford to get a 2 way paging system down the road OR should i just ignore the fact that its even there and just save up for the alarm that I really want?
Old May 15, 2008 | 05:11 PM
95civic1.6l's Avatar
Default RE: old security system.
why not use it. Its worth the 30 dollars
Old May 18, 2008 | 06:42 PM
macbeth18288's Avatar
It's worth a try, as long as nothing else is needed to get everything running.
It's only $30.
Old May 19, 2008 | 06:10 AM
SilverSedan's Avatar
surf the net, see what it does and how old it is...but yea if its on ly $30 then gofor it...a warning tho...sometimes stuff like that winds up being $30+2 here and 5 there and ooops another 10 there...
Old May 19, 2008 | 07:00 AM
Exactly,
which is why i said as long as nothing else is needed to get everything running.
They might tell you that you need another $30 chrage to reprogram the brain to the remote and then another $20 to check all of the sensors, etc.
Old May 19, 2008 | 07:17 AM
I found the service and install manuals for the system online and downloaded the pdf's for them. The copyright on the manual said 2000...so.... It's old, but I'd imagine it should still work. I looked for the valet switch that goes with the system and found it. From what I read in the manual I just have to use the valet switch to program any new remotes and delete old remotes from the system. If it works, I plan on using it until I have the cash to buy a 2 way paging system and a bunch of different sensors.
Strong Island
Feb 14, 2008 06:40 AM
OptimusGeorge
Oct 27, 2007 07:33 PM
95civic1.6l
Apr 11, 2006 09:40 AM
awoconsequence
Mar 1, 2006 09:22 AM
absoulute
Jul 29, 2005 12:02 AM
