REM connection
Old Dec 27, 2006 | 07:25 PM
03civiclxcoupe's Avatar
Default REM connection
i have a alpine deck and polk speakrs and i am waiing for my 4 channel amp to come in but i only have one remote line on the harness of my deck...which i kno is what controls when u turn the sub elvel up or down but do i need to connect that to the 4 channel amp or will it run without it?
Old Dec 27, 2006 | 07:29 PM
Default RE: REM connection
ohhh i did some research someone tlel me if this is right
the rem line is what turn the amps on and off with the deck...so the rem line isn't what controls the sub level when u turn it up on the deck that just goes through the RCAs right?
so to conect to amps i have to just run 2 wire off of the REM on the harness
Old Dec 27, 2006 | 07:36 PM
Marty's Avatar
on Alpine decks when you change the sub level all you are doing is sending or retracting voltage from the RCA's. Full/maxed out is when you get Alpines rated RCA output which is more than likely around 3 to 4 volts
Old Dec 28, 2006 | 03:35 AM
dukat03's Avatar
the REM wire is a wire that goes to your amp and turns the amp on and off when the radio comes on and off that way its not always on . on your alpine it should be a blue or blue with white strip
there is a REM line which is different , the REM line is a bass controller that hooks up to the amps , alpine doesn't provide this wire only the amp companies do , ( its usually option all ) this way you can turn the Bass up and down from the front instead the rear where the amp is
t34me
Aug 10, 2006 11:41 AM
rajantsr
Jun 24, 2006 09:14 AM
khomol
Apr 24, 2006 04:42 PM
skytanker2003
Jan 9, 2006 11:45 AM
Super Mario
Nov 22, 2004 01:03 AM
