remote start on a 5 spd manual??
Old Feb 14, 2007 | 09:13 AM
kman92civicsi's Avatar
Default RE: remote start on a 5 spd manual??
it will roll if u dont have ur handbreak on if u do it will slwo the car down i dont think it will stall though, most likely it will but i dont know. and u need to bypass the clutch, when u install it ,, put a switch to be able to turn the remote starteer on and off under the dash, that way if u lend the car to a friend u can jsut turn the switch off and dont have to worry ab out them hitting sumone if they leave it in gear asnd start it. and i seen sum guys leg pinned against a awall do too leaving the car in gear!
Old Feb 14, 2007 | 10:04 AM
FlipHKD720's Avatar
ORIGINAL: Irishdrunk
Is it blue/black going to clutch interlock switch?
I am not sure, maybe someone can back that up
i think you're right. I think its under the left side of the dash somewhere (probably near the clutch i imagine) If you have a Haynes manual it will probably tell you. I always thoguht it was called something like clutch bypass switch though.
Old Feb 14, 2007 | 10:59 PM
badb0ybilly's Avatar
theres a little button behind right by the clutch.. when you push in the clutch.. it relieves that button.. when you release the clutch, it presses the button. originally i thought that was what i needed to bypass. but its not. because if you push the clutch like an inch.. the button will be out.. but the car wont start unless i push the clutch all the way. i cant see anything else thats actually integrated with the clutch at all.
if someone could take a picture of it that would be amazing.
and theres one more thing. once i find this wire.. how do i go about bypassing it?
thanks a lot guys. i know i sound like a retard here and you're all probabbly like. omggggggg shut up. haha
Old Feb 14, 2007 | 11:30 PM
jeff_o's Avatar
fr!ak! I plan to have my manual civic installed with remote start... but after hearing your horror stories about forgetting to put it in neutral... forget it... i'll just bear the 4 month winter.
dwalsh77
Oct 11, 2011 07:00 AM
hmdaigle
Sep 23, 2008 08:04 AM
jimijam
21
Oct 26, 2006 01:00 AM
CivicEX06
Jul 15, 2006 02:43 PM
hondabboy
Mar 20, 2005 04:32 PM
