sub help
Old Mar 11, 2007 | 06:36 PM
klownkiller's Avatar
Default sub help
hi everyone
tomorrow i am buying an alpine type r 12" to go with this amp.
to get 800w to the sub, should i buy the dual 2ohm or dual 4ohm?
what kind of box should i get?
i was lookin at these:
http://www.sonicelectronix.com/item_7498.html
http://www.sonicelectronix.com/item_7523.html
http://www.sonicelectronix.com/item_7521.html
one last question,
what's the difference between ported and bandpass enclosure?
Thanks in advance,
Jon
Old Mar 11, 2007 | 08:06 PM
Default RE: sub help
i would say the first box.....
with a bandpass box they need to be setup FOR THAT EXACT SUB....
and the 3rd box doesnt say the displacement.... but its like 2.8 before displacement... BUT i dont know about the port displacement....
alpine suggest like 1.7 or 1.8displacemnt
and with that amp you need the dual 4ohm version and wire the sub with both + together and then both - terminals together to the amp... preaty simple...
Old Mar 11, 2007 | 10:03 PM
btw
thanks for all the help, i really appreciate it.
this is the first time ive installed a sub by myself. [sm=smiley5.gif]
Old Mar 11, 2007 | 11:24 PM
Stumasters's Avatar
You're gonna want a Dual 4 ohm sub, if you want to wire it up to runa 2 ohm load.
If you get a dual 2 ohm, you can wire it to 1 ohm, but you would have to have a 1 ohm stable amp, your only other option is 4 ohms, which cuts your amp's power output.
Get a single sub with a dual 4, and any 2-ohm stable amp will push it, but get a mono amp, or you will have to find a 2 channel thats 2 ohm stable in bridged mode. Thats alot tougher to do.
The amp you have picked out should rock out, it's mono too, so you can get almost all of those 800 watts all day long. I would say you will be pounding whatever box you put it in!
post some pics when you get it all in, looks like a nice setup!
And as for the box, I think option 1 there was the best choice, if your not going sealed. Ported will give you some all out punchy bass, should rattle your bones. I never liked bandpass boxes too much, had a dual 12 setup once in a bandpass, it wasn't half as loud as just a standard box setup!
Old Mar 12, 2007 | 11:22 AM
thanks a lot for all the help!
ill get some pix up when i get it all in
having to post pix will motivate me to make the wiring all nice and tidy....damn you guys [8D]
windcalmer
Aug 4, 2007 01:30 AM
Polygamy16
May 3, 2006 09:15 AM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
yonu
Jun 21, 2005 07:04 PM
