Sub Wiring Problems
Old Aug 6, 2005 | 03:17 PM
jafferman2004's Avatar
Default Sub Wiring Problems
well i took out my deck to properly install all 4 of the car speakers (i only had rear ones wired) and ya so i did that all 4 work now, but the subs dont work the rca cables are connected to the amp, the amp has power and the subs are wired properly to the amp, any ideas? like when i play music now i just get the 4 in car speakers workin, amp power is on but the subs arnt workin
Old Aug 6, 2005 | 03:21 PM
Street Sniper's Avatar
Default RE: Sub Wiring Problems
Did you forget to hook the RCA's back up to the head unit? or are you running a H-Lo converter from the back speakers?
Old Aug 6, 2005 | 03:30 PM
ORIGINAL: Street Sniper
the rca cables are hooked from the head unit to the amp. do u think one of the rca cables could of died out?
Old Aug 6, 2005 | 03:39 PM
Not likely.
All things being equal, the simplest solution is usually the correct one. Which means look at all of the dumb stuff first before you start replacing cables and ripping stuff out.
Is the fader centered? Do you have a Sub output on anything and is it turned on? Is the bass turned up? Do you have the cables in the right connections (input, output, highs, lows)? Gains up and crossovers set correctly? Maybe the cables just came undone when you pushed the head unit back in.
If all of this and all the other simple stuff is Ok, then try those cables to a known good amp, and then try the amp on a known good input.
Old Aug 6, 2005 | 03:43 PM
inside 4 speakers are working so wouldnt the only factor for the subs not to work would be the rca cables? from the deck to the amp cuz it was workin fine before
Old Aug 6, 2005 | 03:55 PM
That's the sort of thinking that makes people overlook stuff.
Is it an aftermarket deck?
Old Aug 6, 2005 | 04:18 PM
ya its a pioneer some old one but i know it works, i just tried a different amp that i know that works and i heard a pop on the subs when i plugged it in, so i know the amp and subs work but yet the rca cables from the deck to the amp im still suspecting that.
Old Aug 6, 2005 | 04:41 PM
its either that or the deck is ****ed
Old Aug 6, 2005 | 04:50 PM
splman75's Avatar
Try checking continuity on your rca's
Set your meter to continuity and touch one probe to one end of the rca and the other probe to the other side. Make sure when you do this you touch the center pins then test the sheild. You may have a break.
Also you could hook up your volt meter to the outputs on your deck make sure your testing for AC . then turn on your radio your voltage should fluctuate with the music. If not your outputs are bad.
Old Aug 6, 2005 | 07:16 PM
mill$civic's Avatar
i had the same problem with my old set up, when i wiggled the rca that plug into the amp, it would go on and off depening where i held it so i bought new rca cables, well, turns out that the rca cables were fine but it was where the rca plung into my amp that was screwed up, it was a ****ty amp so i took it apart and did some surgery and got it working, later on it would screw up again..
