subs thumping like hart beat! What does lpf, full, hpf mean?
Old May 8, 2008 | 02:14 PM
  #41
T3rry's Avatar
Member
Default RE: So, sonic electronix gave me a call.help me!
a picture says 1000 words... seriously, that post si so confusing it makes no sense at all.
Old May 8, 2008 | 02:27 PM
  #42
enigma34's Avatar
ORIGINAL: T3rry
ok i go take picture, stay online!
Old May 8, 2008 | 02:48 PM
  #43
enigma34's Avatar
<a href="http://tinypic.com" target="_blank"><img src="http://i27.tinypic.com/r2l0d3.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i29.tinypic.com/a2btz9.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i27.tinypic.com/5n96rp.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i29.tinypic.com/5xvihy.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i26.tinypic.com/2cc1dz.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i25.tinypic.com/16c89c0.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com" target="_blank"><img src="http://i29.tinypic.com/11mbak1.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old May 8, 2008 | 07:20 PM
  #44
gunz4me's Avatar
ORIGINAL: enigma34
Ok, so i have taken out my stock radio.
i HAVE 5 typs ofwires,
1. is for the antena
Yep
ORIGINAL: enigma34
2. is this plug that looks like a headphones jack? i think its for the 6 cd changer.
That is a DIN plug that works with Alpine M-Bus products and/or the factory tape deck. So yep!
ORIGINAL: enigma34
Now i have 3 plugs wrapped together in a black tube. two green plugs and a white plug.
A short green one was pluged into the radio also, but i dont know what it is?
The longer green plug, plugs into the HONDA SECURITY MODULE, that is screwd on the stock radio.
and the long wite plug, im gessing is what the aftermarketharness will plug into?
The white one should be the only one you will need since you are trashing your factory head unit! The green plugs are for the security system and the factory keyless, which you said you were going to deep 6 anyhow. Do you want me to post a pic of my harness that will plug into the factory white harness? It is already soldered, heat shrunk, and taped. It doesn't look pretty, but you will give you an idea...
ETA: So that is where I can expect to find the alarm when I yank the factory radio out of my late wife's 1997 Civic EX and THAT is what they charged over $350 for her to put in the car? Good grief, there is NO WAY that was worth $175 for the alarm unit and $175 to install.....
Old May 9, 2008 | 03:15 AM
  #45
enigma34's Avatar
ORIGINAL: gunz4me
ORIGINAL: enigma34
Yep
ORIGINAL: enigma34
ORIGINAL: enigma34
Thanks
Naaa, you dont need to post a pic. But im not going to buy a solder,im just going to buy a crimp set.
Old May 9, 2008 | 03:45 AM
  #46
enigma34's Avatar
Default RE: sonic electronix gave me a call. updated, with pics!
Do you know how to remove the tape deck? im having a tuff time with it!
Old May 9, 2008 | 07:13 AM
  #47
gunz4me's Avatar
Yeah, you have to remove the whole friggin console to get the tape deck out! After the console is out, there should be 4 bolts (two on each side) holding the tape deck in.
ETA: Crimps done properly will work just fine for installing your radio. I prefer solder because it works better on boats whereas crimp on connectors just corrode and break when exposed to the elements and salt water.
ETA2: I am one of those uber **** "overkill" people. My connection will outlast the item it is connecting in 99% of the cases!
Old May 9, 2008 | 07:38 AM
  #48
enigma34's Avatar
ORIGINAL: gunz4me
The console, is the plastic all a round the shifter?
Old May 9, 2008 | 07:46 AM
  #49
gunz4me's Avatar
The console as in first you pull the arm rest section, then you remove the plastic around the shifter. I think you just need to remove 8 screws, but be REAL careful when pulling.
ETA: I think you may need to remove your shifter **** too.... I don't remember if the plastic will clear the shifter or not...
Old May 9, 2008 | 02:59 PM
  #50
enigma34's Avatar
ORIGINAL: gunz4me
THANKS, i got it out.
Therewas a cablethat was leading under my carpet, it conected to the tape deck, and the wire coming out of the tape deck ran up to the radio. I thought this was the antenna cable? Know, that i disconected the tape player, i dont think this cable that was coming out of my rug from the arm rest, That plugged into my tape deck,will reach my new radio...
Where is the input for the antenna? Is it that long black cord all the way to the left? Or is it that input to the right of the two red RCA plugs?
http://www.sonicelectronix.com/pictures.php?id=8869
Also the cord all the way to the right, what is that for? my stock radio did not have it, where do i plug it in?
