tach problemssss
Old Jan 7, 2009 | 07:15 AM
nineteenninetynine's Avatar
Default tach problemssss
helloo i just swapped a gsr into my 99 ex and everything is working fine but the tach doesnt seem to be working..
i checked all the wiring diagrams and there is a blue wire coming off the distributor that says that is a tach wire but there wasnt one on the d16y8..
any ideas?
Old Jan 7, 2009 | 12:47 PM
texasmade's Avatar
um yeah its the blue wire and it the y8 should have it to
Old Jan 7, 2009 | 01:18 PM
^+1
it should be there
Old Jan 7, 2009 | 01:38 PM
the y8 should have it?
where do i connect the blue wire coming off the distributor?
Old Jan 7, 2009 | 02:57 PM
It comes from one of the pins on the ICM module inside the distributor. It will be the only wire connected to that pin. Look at your old distributor to compare. I think all the ICMs are the same.
You need to take the rotor off and take the plastic plate out to see the ICM. Be sure to put the plastic plate back in when you're done.
pkfrdh
Mar 22, 2005 11:38 AM
klamslam
Jan 29, 2005 01:46 AM
Super Mario
Jan 10, 2005 10:35 PM
dalifts
Dec 16, 2004 10:34 PM
onequick4
Oct 23, 2004 09:30 PM
