Turbo Timer
Old Apr 10, 2009 | 04:37 PM
95boostedcivic's Avatar
Default Turbo Timer
Hi guys I'm new to the site and pretty new to Hondas.
I just picked up a 95 Coupe and was wondering if any of you can help me with my Greddy turbo timer.
So far I got it where it will power on but will not keep the car running or even count down.
Any help would be much appreciated
Old Apr 10, 2009 | 05:45 PM
315 Customs's Avatar
There should be three heavy gauge wires
1: Constant 12 volt supply
2: Ignition source
3: Accessory Sorce
For your vehicle you will connect to the follow factory color wires (off the ignition switch, same order as above)
1. White
2. Black/Yellow
3. Yellow
If you want more descriptive instructions you will have to post the exact type of turbo timer you have.
Old Apr 10, 2009 | 06:15 PM
Old Apr 10, 2009 | 10:55 PM
FlipHKD720's Avatar
Old Apr 10, 2009 | 11:11 PM
gsumano's Avatar
recheck your wiring... I had the same problem with mine when I first installed it. The timer would turn on when the car was on but it will not stay on for the count down. Turn out that one of my wires was loose.
Also if the little switch on the back is not switch to the correct setting the timer won't stay on.
Old Apr 11, 2009 | 01:16 AM
2: Ignition source
3: Accessory Sorce
1. White
2. Black/Yellow
3. Yellow
Sorry about that its a Greddy Full Auto TImer
Old Apr 11, 2009 | 01:18 AM
does it turn on by itself? I have to push the power to turn it off.
I tried switching the wire around a little but with no luck.
I will take a look at the switch on the back today.
Thanks for the info
Old Apr 11, 2009 | 01:19 AM
then just follow the link TrustDestruction posted, it'll tell you exactly how to install it
Old Apr 11, 2009 | 11:33 AM
I tried doing what the manual says but with no luck.
I'm thinking maybe the turbo timer is messed up?
Old Apr 11, 2009 | 02:08 PM
double check your connections and test the wires with a multi-meter. Ignition should hold voltage during crank and accessory should drop voltage during crank.
If everything is hooked correctly and to specs then its probably a faulty timer.
riceburner700
Jan 26, 2006 09:15 PM
97exhonda
Dec 21, 2005 06:43 PM
Pete
Aug 28, 2005 07:19 PM
se7ensectoolate
Apr 25, 2005 10:40 AM
ZzZzz EH2
Jun 1, 2004 03:06 PM
