Viper 5002 … Power Wires help?
Old Oct 23, 2009 | 05:01 PM
Sigracer10's Avatar
Originally Posted by Karado58
So I understand:
87 on siren relay to 520T GRAY
5002 H1/2 RED (15A fuse) to 520T GRAY
520T RED to 12V Constant (15A fuse)
Thanks for helping!
Assuming that the Gray is the battery backup's +12V output, then yes that all looks right.
Old Oct 23, 2009 | 05:49 PM
Karado58's Avatar
Correct, Gray is the battery backup's +12V output.
12 to 14 gauge wire Ok to the 12V?
Thanks so much Sigracer10. This whole alarm install has been a great learning experience.
Old Oct 23, 2009 | 07:21 PM
Sigracer10's Avatar
I actually though that you were powering a lot more components when I recommended the 12 to 14 gauge wire. you should actually be just fine with using the same size wire as the battery backup uses, which is probably 18 or 16 gauge wiring.
Old Oct 23, 2009 | 08:43 PM
Karado58's Avatar
Smile
Thank you for your advice Sigracer10.
Karado58
Oct 26, 2009 10:05 AM
Karado58
Oct 26, 2009 09:57 AM
Karado58
Oct 14, 2009 09:38 AM
Karado58
Oct 4, 2009 04:26 PM
Karado58
Sep 30, 2009 10:55 AM
