Chop Shop Tutorials DIYs for use in photoshop, gimp, etc.
Tutorial: Wheel Chop Using Photoshop
Old Jan 24, 2010 | 02:27 PM
Default Tutorial: Wheel Chop Using Photoshop
Mods maybe this tutorial should be stickied.
There's many of you guys that ask for wheel chops and some of you guys might have Photoshop so here's a tutorial for doing wheel chops. There are many ways to chop wheels, this is my way that i use to do wheel chop. I am using Photoshop CS.
Remember: The better and higher the resolution the better the outcome will be. For best results find cars that are at the same resolution and as close to the same angle as possible. Also, for best results, DO NOT use the same wheels for the front and rear. Use the front wheels for the front wheels and the rear wheels for the rear wheels.
Find Donor Wheels Pictures. The sites that i like to looks for images are google, flickr, and bing
This is the car that i will be doing the chop on. I will try to be as detailed as possible.
1) Open Up your car you want the wheel chop AND the donor wheels pictures opened on photoshop
2) Select the "Elliptical Marquee Tool." You might need to right click the option and select it
3) Make a Circle. Right Click and Select "Transform Selection"
4) Drag the Corners and stretch it or rotate it so that the circle perfectly outlines the wheels. After you get that right, Press the "Enter" key
5) Select the "Move Tool" and drag the circled wheel onto the car that you want the wheels on.
6) Press "CTRL + T" to free transform the wheel that you've just dragged. Scale, Rotate, and or drag the wheels till they fit over the original wheels. Pretty much similar to step # 4. AND Press the "ENTER" key.
REPEAT STEPS 2-6 FOR THE REAR WHEELS
Here is what you will end up with
NOW... if you want to save the picture. Click "File" --- "Save As" . Rename It. and In format select in the drop down menu "JPEG" or whatever format you want to save it in. and click "Save" and click "OK"
And there you have it.
ENJOY this tutorial and good luck. Hope this helps many of you guys and if i get enough interest in this thread i will make a tutorial for lowering a car as well.
Old Jan 24, 2010 | 03:08 PM
Dontoh's Avatar
great job (Y)
Spoolin.Em
Sep 22, 2011 05:18 PM
GReddy_Civic
Oct 30, 2007 06:49 AM
Patrick
Audio/Video & Electronics DIYs
Sep 11, 2006 02:32 PM
my_hidden_romance
Jan 12, 2006 10:03 PM
Amanda
Interior DIYs
Apr 18, 2005 12:29 PM
