afc understanding
Old Nov 9, 2005 | 01:40 PM
austin_Springer's Avatar
Default afc understanding
so a vafc, it allows you to change to the voltage of the meter that's measuring air input, and modifieiying it, so if you use bigger injectors, and turn the voltage down you will be just like stock? correct? so for a boosted d16z6 i would need bigger injectors, v-afc, and a turbo, piping, oil lines, IC, BOV, and a boost controller correct? what else would i need if i weren't just going to get a kit?
Old Nov 9, 2005 | 11:28 PM
fast93civic's Avatar
Default RE: afc understanding
Well, if you wanna keep it at stock boost, you dont have to get anything but the turbo kit. But if you wanna boost up, then boost controller,bigger injectors, vafc, or hondata, and a tune, far as I know.
Old Nov 10, 2005 | 08:30 AM
the thing is is that i wouldn't be getting a kit, i would be piecing it together by myself...
Old Nov 10, 2005 | 11:21 AM
Dickie's Avatar
Member
piecing together can be the way to go if you buy parts that are amazing when paired with each other, but good luck lol.. its hard. youre forgetting a waste gate. oh.. and what size injectors where you thinking about using?
Old Nov 10, 2005 | 01:33 PM
yes i would also need a wastegate, and a turbo manifold, not sure what size injectors i should get though, 440's is popular i think
do i have the concept of the afc right though?
MarcB
EG Swaps
Jan 30, 2007 09:42 AM
FlipHKD720
Jun 12, 2006 07:14 AM
XCM828
Dec 1, 2005 10:45 AM
Xoopiter
Oct 11, 2005 08:06 PM
Auto98EX
Sep 28, 2005 11:27 PM
