Alternator?
Old Sep 5, 2005 | 09:56 PM
mxs's Avatar
mxs
Default Alternator?
If my interior lights (and glow gauges) kind of flicker when the engine is running, but not when the engine is stopped, is that a problem with the alternator? should I be worried? I think it's always done this but I never really thought about it before today.
Old Sep 5, 2005 | 10:06 PM
Street Sniper's Avatar
Default RE: Alternator?
Hmm, flicker? or do they dim when at idle and get brighter when you rev?
Old Sep 5, 2005 | 10:29 PM
mxs's Avatar
mxs
When it's idling they kind of pulse... um, I'll have to check tomorrow, I don't know if they get brighter or stop flickering when I rev the engine.
Old Sep 6, 2005 | 09:05 PM
mxs's Avatar
mxs
When I rev the engine they still seem to flicker. They don't flicker all the way OFF or anything.
Old Sep 6, 2005 | 09:07 PM
It is probably just a ground then. If it was the alternator the lights would get brighter with the rpm's. Unless someone knows something I don't.
Old Sep 8, 2005 | 10:19 PM
mxs's Avatar
mxs
Bad ground, eh? Why would they stop flickering when I shut off the engine?
This seems to be affecting the dome light, the map lights, and the glow gauges (which I hope aren't the problem because I don't think I want to take the gauge cluster apart {although, 3 months ago, I didn't want to take anything apart!}).
Old Sep 8, 2005 | 10:29 PM
ngoti 8tor's Avatar
I would remove the battery connections and clean them up with a wire brush. I always cover the connections after cleaning with a thin layer of grease to stop any further oxidation.
Also, make sure your ground is good on the chassis. It wouldn't hurt to add a few more grounds if you have some good thick and flexible wire (braided).
Old Sep 9, 2005 | 12:12 AM
sacicons's Avatar
and get the battery and alternator tested at a parts house. they will usually do it on the car for free.
grunge
Sep 24, 2006 09:00 PM
Hitesh0528
Sep 12, 2004 04:34 AM
gblack59
Aug 20, 2004 05:06 PM
pingu
Jul 23, 2004 05:29 PM
bills99si
Jul 2, 2004 04:43 PM
