Check Engine Light
Old Jun 5, 2007 | 07:10 AM
bcrichguitars's Avatar
Default Check Engine Light
Is it normal for this light to flash on while starting the car and then disapear right away?
Or is this actually an engine light indicating something?
I have a chipped ECU so I'm pretty sure I could pull the code if I did some more research, anyone know if I need to worry about it?
Old Jun 5, 2007 | 07:31 AM
mlobitz's Avatar
Member
Default RE: Check Engine Light
normal, just making ssure the light works. If it stops flashing you ned to replace the bulb.
Old Jun 5, 2007 | 07:53 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
when you turn the key to run the check engine light should come on then go off. this is normal for every honda.
miguel11691
Nov 15, 2015 08:11 PM
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
Benny Sim
Jul 19, 2005 07:43 PM
