Difference?
Old Oct 22, 2006 | 03:59 PM
t34me's Avatar
Default Difference?
Hey, this might sound stupid, but im not to caught up on ignition systems. What is the difference between these 2 setups:
This one is $70
[IMG]local://upfiles/11033/F2CB6C3473814AC2BB225166E01EF19B.jpg[/IMG]
This one is $200
[IMG]local://upfiles/11033/1BC227BE8BC8461197D4C2E4C350E020.jpg[/IMG]
So what gives, can i use the first one without buying the box that jacks up the price $130. Can i get away with using the first one if im just boosting 8psi?
Old Oct 22, 2006 | 04:03 PM
ef4life's Avatar
Default RE: Difference?
the top is just an external coil and a dizzy cap. pretty much a cheap upgrade. the bottom is an ignition box. that actually controls the ignition. your stock ignition should be fine, but an upgraded exteranl coil is good. i run a msd blaster 2 in my car, and a stock ignition system.
Old Oct 22, 2006 | 09:14 PM
t34me's Avatar
so the external coil and cap would be a good option with the stock ignition? Hmmm...sounds good, might have to purchase that
Old Oct 22, 2006 | 09:46 PM
Marty's Avatar
you are boosted go with the ignition box, you need to be able to change timing easy
02CivicEX
Jan 26, 2005 02:28 AM
queenb
Jan 24, 2005 09:54 PM
02CivicEX
Jan 24, 2005 12:37 AM
sab
Oct 20, 2004 09:56 PM
civicguy1xxxxx
Jun 27, 2004 04:54 PM
