ECU location
Old Jun 24, 2006 | 12:28 AM
pmansyourdaddy's Avatar
Default ECU location
I have an 03 civic ex, can someone tell me where the ECU is located, and maybe give a suggestion on a good EMS
Old Jun 24, 2006 | 07:11 AM
Chimera02EX's Avatar
Default RE: ECU location
Your ECU is behind your glovebox. What do you have done that you need an EMS?
Old Jun 25, 2006 | 01:27 PM
Here is a picture, the yellow outline is where your ECU will be.
Old Jun 25, 2006 | 03:56 PM
well i am putting a new turbo in, and new 02 sensors, and i want to change the air/fuel ratio, i mean a stand alone EMS i hear is good ****, im used to old american muscle so i am not familiar with the whole computer concept. You got any advice, is it possible to just go with a piggyback system or what? I mean which would provide the best results?
Old Jun 25, 2006 | 04:30 PM
Ok EMS is your best option if you have the money to purchase it. You prolly could get away with a piggyback but an EMS would give you much more gains and provide better stability. AEM is your only option. it runs between 1700-2000, plus I suggest a couple hours on a dyno w/ a pro tuner.
Old Jun 25, 2006 | 08:41 PM
any idea on how much that runs for? have you heard anything about a company called megasquirt? They make to be stand alone EMS but for the fraction of the cost.
Old Jun 26, 2006 | 08:30 AM
Yeah the problem is most EMS companies make EMS systems for OBD1 not OBD2 and definately not OBD2b. AEM is pretty much your only option in an EMS it'll run you about $1700. YOu could do more research about this megasquirt company but make sure that their EMS will work with OBD2b. And the AEM EMS for the 7th gen won't get rid of your stock ECU.
Old Jun 26, 2006 | 10:13 AM
I thought the stand alone EMS do replace your whole ECU
Old Jun 26, 2006 | 10:53 AM
Not for our car. AEM's EMS needs our stock ECU to run a couple things; don't recall exactly what they are offhand and I think you can do without them.
Old Jun 26, 2006 | 01:05 PM
I think its probably stuff like cruise control and all the misc. stuff that gives our car the EX title, cool thanks bro i appreciate all the help
chipguy1
Sep 15, 2010 05:00 AM
norman
Nov 22, 2009 09:40 PM
guate2006
Dec 17, 2008 06:03 PM
ic892003
Mar 14, 2007 11:17 AM
superfestiva
13
May 26, 2006 04:20 PM
