Engine swap problem with starting
Old Sep 2, 2006 | 09:22 PM
pallo88's Avatar
Default Engine swap problem with starting
I have a 1990 honda civic cx hatchback. I purchased a 1992 si vtech engine, the enging went in ok, and it wants to start but it just won't fire. I had to get a new distributer to go with the engine, and to do this you have to change the wiring to it from a 5 pin setup to a 7 pin setup. I'm just wondering if I messed up the wiring. I'm getting spark but the engine just won't go. Does anyone know the wiring that needs to be done for it. its a change from a 1990cx distributer to a 1992 si vtech distributer.
Old Sep 3, 2006 | 05:17 PM
MY99SI's Avatar
Default RE: Engine swap problem with starting
did you plug in the fuel injector harness, or what about the coil? check for loose wires or grounds that arent hooked up
Old Sep 6, 2006 | 10:38 PM
street tech 33's Avatar
is it a dual injection car cause if it is you need to change it to the 4 injector fuel sytem
djt
Jun 21, 2008 07:48 AM
totenkopf
May 31, 2007 03:36 PM
Expando1
Aug 12, 2005 08:34 PM
terraeisa
Jul 14, 2004 10:23 PM
raphn
Jun 14, 2004 02:07 PM
