External coil installed, now tach jumpy
Old May 23, 2010 | 02:20 PM
PhilStubbs's Avatar
Default External coil installed, now tach jumpy
I recently installed a an external coil and MSD cap. I runs fine, but the tach is jumpy under 3k and above there it's pretty much gone. Turning the headlights or brake lights on helps it work better. Kinda sounded like a ground problem so I checked and cleaned every ground, then added a bunch more. No change.
The only change was the external coil. I'm tryng to find a spare distributor I have to see what happens, but can't seem to find it since I moved
Old May 24, 2010 | 09:57 PM
where do you have your tach wire hooked up at? or is it a factory tack built into the cluster
Old May 25, 2010 | 02:57 AM
PhilStubbs's Avatar
Stock tach. It ended up being the ignitor
thakid
Nov 16, 2006 06:48 PM
joe383
Jul 6, 2006 09:02 PM
natlbnldr
May 4, 2006 02:38 AM
thakid
Apr 25, 2006 09:17 AM
dalifts
Dec 16, 2004 10:34 PM
