harness pins, help!!!
Old Jan 25, 2006 | 10:50 PM
smokingemcee's Avatar
Default harness pins, help!!!
Hey I have to put in my vtec subharness tomorrow and was looking at the harness and noticed how hard it will be to remove the pins I need to. My intructions say I need a honda tool for it. Is that right? Any tricks? Should I just go buy that tool?
Old Jan 25, 2006 | 11:06 PM
jwsimons's Avatar
Default RE: harness pins, help!!!
i destroyed a plug.. and had to solder in a new plug, one wire at a time. but that was at the ecu. i have had no problems with plugs in engine compartment.. use something nice and pointy, like an ice pick or light tester. pop the internal tab up and pull out the wire.. if you have the square type plugs, first you must remove the white peice from the inside. just pull on it, it will come out!!!
Old Jan 25, 2006 | 11:18 PM
jwsimons's Avatar
i notice you and i have the same project (more or less) going on. did you decide pr3 (which i have) or did you go with pwo? what are you installing into?
Old Jan 25, 2006 | 11:32 PM
I am installing a b16a1 into my 1990 civic si hatch. I have a pr3 ecu and the hasport v-tec subharness.
Old Jan 26, 2006 | 12:44 AM
finalimpact's Avatar
paper clip and sand paper is all you need to fashion a temp tool for de-pinning. straighten out the paper clip, then sand one end down till its flat enough to get in the clip. jw ive never been lucky enough to pull my wires out....you lucky ....[:'(]
Old Jan 26, 2006 | 01:15 AM
jwsimons's Avatar
really? ive had no trouble on any in the engine harness!! its everything else im having dificulty with... damn color coded wires
ORIGINAL: finalimpact
rc2904
Feb 24, 2011 07:11 AM
02civcoupe
Sep 17, 2006 08:29 PM
hondadelsoldrvr
Mar 17, 2006 12:50 AM
steven87ukuk
Feb 13, 2005 11:10 AM
RiceBurner
Jan 17, 2005 08:20 PM
