Help with fuel problem on NEW 00 SI
Hey guys my girlfriend just bought a 00 civic si and we are having problems with it. This was off the dealer as is. So far I can tell is the car has intake exhaust fuel rail aem fuel regulator ford injectors and a pressure gauge that is pegged past 100 psi. I know the gause is broken becuase I released the pressure and it was stuck at 70psi but i just ordered a new one to pick up tomorrow.
The problem is it is idling high at stops around 3k rpms then drops to 1k after 2 secs. Im guessing becuase the pressure is uber high. Im trying to adjust the regulator but there was no nut and bolt on it. So I bout a nut and bolt for 87 cents. Once I get the gauge I am going to try to adjust it.
Now on the regulator if i tighten it will that bring down the pressure? because i thought if you loosen it would lower the pressure. I think I want to lower it to 40 psi if that is stock.
And ford fuel injectors? i never heard of. This puppy is eating a lot of premo gas...
Lose the injectors and FPR. FPR's are jank *** **** unless you spend money on a good one, it's most likely a big part of your problem.
Get some 240cc honda injectors, and a stock fuel pressure regulator for a whopping $50 total and see what that does.
CivicEX2006
Sep 20, 2007 03:32 PM
4doorcivic9
Jul 11, 2007 10:54 PM
TheBlackCivic
Jul 16, 2006 11:45 AM
nightrider46
Aug 23, 2005 03:42 PM
