Help keep getting P0500 code!!
Old May 12, 2010 | 02:39 PM
fattyjon2002's Avatar
Default Help keep getting P0500 code!!
I have a 99 Honda Civic and I keep getting a P0500 code in my ECU. I know this is for a problem with the Vehicle Speed Sensor. I have changed the VSS sensor and the speedometer in the dash. I have even broke out the multi-meter and checked to ohms and volts of the circuit. It seemed to be alright, for I got the right measurements for the ohms and volts I was supposed to. I know that the o2 sensors are ran in the same circuit as the VSS sensor. I was just wondering if anyone of the Honda gods on this forum have any clue as to what is wrong with my car.
P.S. Any links and info you could include would be great and much help.
thanks for everything
fattyjon12002
Old May 12, 2010 | 03:33 PM
Check whether dash 7.5A fuse #15 is blown.
The VSS plug is a notorious source of problems. Check it for corrosion and moisture. Many people find a Civic at a junk yard and cut off the VSS plug and splice it into their wire harness.
stylincompact
Jan 2, 2008 05:11 AM
Revn7
Aug 31, 2007 05:09 AM
TBon3
Mar 24, 2007 11:58 PM
psychocivic
May 22, 2006 08:23 PM
