I need help!!!!!!!!!!!!!!!!
Old Oct 21, 2008 | 05:56 AM
Low 4 Door's Avatar
Default I need help!!!!!!!!!!!!!!!!
Hi guys I really need some help. my 91 civic 1.5 is being a really big pain. so heres the problem. about a month ago the car started idiling real rough, kinda sounded like a WRX when you started it up. i read the code from the ecu and got code 16 which is the fuel injector code. so last sunday i went out to the junkyar and bought 2 fuel injectors and a main relay. helped but still runs rough. the next thing im thinking is fuel pressure regulator.
any ideas thanks
Old Oct 21, 2008 | 06:24 AM
Did the replacement parts clear CEL code 16?
Old Oct 21, 2008 | 07:40 AM
Low 4 Door's Avatar
yea the code cleared. i also am thinking that i might have a blown head gasket. the car has 168xxx miles and im trying to keep it running long enough to get the money fora possible swap.
Old Oct 21, 2008 | 07:46 AM
What's the engine?
Why do you think the head/head gasket is blown?
Old Oct 21, 2008 | 07:48 AM
Low 4 Door's Avatar
its a D15b2 its just another thing on my check list. also the number 2nd sparkpug from the left gets fouled very easily.
Old Oct 21, 2008 | 08:45 AM
You may want to start with a basic tune up (OEM plugs, wires, distributor cap, and rotor).
Any smoke from the exhaust? Are you losing oil and coolant? Is the engine overheating?
Old Oct 21, 2008 | 08:51 AM
Low 4 Door's Avatar
I have recently done the tune up. back in june i replaced the distributor, plugs, wires, alternator, valve cover gasket, adjusted the valves. there is blue smoke comming out of the exhaust and it uses about a quart of oil a week. engine does not overheat. and does not use any coolant.
Old Oct 21, 2008 | 10:22 AM
Compression and leak down tests may be in order to determine whether the oil burning in cylinder 2 is caused by a bad valve seal, piston ring, or head gasket. I guess bad cylinder 2 may be the root cause of the rough running engine.
Compression test - see forum DIY section (by Forty04).
Leak down test - http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Old Oct 22, 2008 | 06:33 AM
Low 4 Door's Avatar
That was another thing on my list to do. if that doesnt work out i will be out of ideas.
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
