Injector help!
Old Jul 13, 2007 | 03:56 PM
LarsonSi_0091's Avatar
Default Injector help!
well ok the problem now is i have a d16z6 swapped into my 91 crx i got the conversion harness to go to obd0 to obd1. well now i got it to fire on starting fluid. i got fuel all the way to the fuel rail. i am running the obd0 injectors with the stock restior box.now its just the injectors will not pump any fuel to the cylinder does anyone have any answers? am i gonna have to switch the injectors to obd1 cause from what i have read i should be able to use the obd0 injectors.
Old Jul 16, 2007 | 03:38 AM
Default RE: Injector help!
If you're running an OBD1 motor, you need to be running and OBD1 fuel system/management.
What ECU do you have?
Old Jul 16, 2007 | 12:03 PM
ok that i was before now i did the swap with the injectors and got rid of the resistor box repinned it into a cap off plug. repinned the injectors for the obd1 injector clips so everything is obd1 that needs to be but i still cant get the injectors to pump fuel into the cylinders. i am running the p28 ecu and also i checked out what codes the ecu was throwing i got some oxygen codes and water temp code thats it.
Old Jul 16, 2007 | 12:05 PM
oh yea and i also checked with a test light to see if i was getting power to my injectors and i am
Old Jul 16, 2007 | 04:25 PM
oh i also found out that im getting power to both sides of the injectors and im only supposed to have power on one side do you have any clue what that could be?
redlines4us
Apr 25, 2021 06:20 PM
89_slammed
Mar 19, 2007 01:11 PM
birdmane
Mar 14, 2007 08:17 AM
BOOSTINEX
Sep 10, 2006 03:54 PM
t34me
Aug 10, 2006 10:51 AM
