my car cant hit 7200rpm
Old Oct 19, 2006 | 11:32 PM
intense_gravity's Avatar
Default my car cant hit 7200rpm
i have a 94 civic eg coupe and i cant even come close to redlining it at 7200rpm.. it only goes up to 6200rpm then my redline bounces ... what could i do to fix that problem... i've done everything i could to fix it but still it does the same thing.. i had a friend sayit might be my ecu cause i have a spoon chip in it but whwen i ran his ecu the p28 still does the same thing... could it be the wiring or something else.. if you can help hit me up that would be great...
Old Oct 20, 2006 | 07:22 AM
Default RE: my car cant hit 7200rpm
ORIGINAL: intense_gravity
what exactly did you try and do to fix the issue?
Old Oct 20, 2006 | 10:33 AM
i tried reseting the ecu ... looking to see if my rpm connection line for the ecu plug is hooked up.. also my timing>>
Old Oct 20, 2006 | 01:19 PM
amg6975's Avatar
I bet it's just that your tach isn't reading correctly.
Old Oct 20, 2006 | 02:30 PM
my tach is reading perfectly fine.. my tach and my friends tach is the same ... my ecu redlines in his coupe at 7200rpm but when i put it in mines it goes up to 6200 rmp only... i can also still feel more power when my redline bounces... i dont even get my top end pwer.. by the time my v-tech opens at 5500 i'm getting ready to shift already at 6000-6200 rpm.... what could the problem be then..
Old Oct 21, 2006 | 09:46 AM
StifflersMom's Avatar
Cat Fuсker
your phone opens at 5500?
j/p. is the ecu throwing any codes? Which trim level is your coupe? dx, ex? what's the engine code?
Old Oct 21, 2006 | 12:52 PM
SovXietday's Avatar
Take the spoon chip out...
Old Oct 21, 2006 | 12:57 PM
i have another ecu on the side... its a p28 and its not chipped... still have the same problem.. and i dont even have a check engine light.... weird huh... no check engine light replaced an regular p28 ecu and still does the same thing.... i've worked my *** off on it.. hahaha..it not so funny when you can get burned by dx.... haha.. oh yea.. mines a 1.6 liter ex.... d16z6
whitworthsean
Nov 8, 2007 09:22 PM
centexracer254
Aug 6, 2007 07:01 PM
mybrokenblinker
Apr 16, 2007 12:51 PM
intense_gravity
EG Swaps
14
Mar 16, 2007 02:28 PM
baker
Feb 27, 2006 07:30 AM
