Need to Upgrade Injectors
Old Jun 5, 2009 | 09:06 PM
bcrichguitars's Avatar
Default Need to Upgrade Injectors
I'm getting my car tuned to 14psi next friday with my 460cc low impedance rx7 injectors. I'm going to tune to 20ish psi at a later date but I'm not sure if I want to get low or high impedance injectors? I was thinking 750cc RC inejctors that are high impedance, this would make the wiring less complicated and I could get rid of my resistor box as well. Are high impedance injectors just as good as low impedance on turbo applications?
Old Jun 6, 2009 | 01:40 AM
high impedance are plug n' play in OBD1 engines. Just as good as low impedance, actually better since they're plug n' play.
Old Jun 8, 2009 | 07:51 AM
bcivic's Avatar
Well since you already have the resistor box wired in I would get the low impedance injectors because they are peak and hold and in general are a bit better and also usually a bit less expensive since they are more commonly used in the aftermarket, but I would like to suggest you look into precision injectors like the 680cc that I have or even their 1000cc they are more than fairly priced and have performed well for me. Good luck with your new tune.
marspark
Apr 10, 2009 08:44 AM
Stumasters
Mar 19, 2007 01:59 PM
mugen93
Jan 7, 2007 08:29 PM
Uber
Aug 28, 2006 04:40 PM
schweigel
Sep 13, 2005 04:22 PM
