Paperclip in the jumper?
Old Aug 25, 2007 | 10:18 AM
asdfbrendan's Avatar
Default Paperclip in the jumper?
ORIGINAL: Forty04
You can't just adjust that screw, follow the manual for setting idle.
Paperclip in the jumper by the ecu
Pull the plug on the IACV
Start car (will probably run crappy)
Adjust Idle screw until RPMs reach ~450
Shut off car
Plug in IACV
Pull paper clip out of jumper
Start car, should idle around ~650ish
keep in mind this is for 92-00 SOHC vtec motors, numbers will vary for DOHC, non-vtec, etc
Trying to adjust my idle screw...What does Forty04 mean by "paperclip in the jumper by the ecu"?
Old Aug 25, 2007 | 10:33 AM
Pete's Avatar
Default RE: Paperclip in the jumper?
The ECU jumper under the dash. The 2 plastic adapters need to be connected, thus a paperclip will work. Theyre under the passenger side dash.
Old Aug 25, 2007 | 10:54 AM
Alright, I'm gonna go take a look. Thanks...
Old Aug 25, 2007 | 11:15 AM
Anyone have a picture? I'm assuming you're talking about the kick panel where the ECU resides. What exactly am I supposed to be connecting together?
Old Aug 27, 2007 | 03:42 AM
It's in the kick panel up above the ECU. It's a blue two pin jumper plug. Put one end of the paperclip in each "port" on the plug so that you're connecting the two sides of the plug.
Cyborg Ninja
Jun 22, 2015 09:46 AM
ForeverAgo
Nov 6, 2014 11:23 PM
bmxbikes
Jun 30, 2006 09:43 PM
GILL1969
Jan 22, 2006 04:49 PM
headshok2002
Oct 1, 2005 02:09 AM
