problem with idle when engine is warm help!
Old Apr 20, 2006 | 02:11 PM
96civic285whp's Avatar
Default problem with idle when engine is warm help!
I have a 96 civic ex with a gsr swap and a t3/t4 turbo. Ever since I installed turbo the car wants to swing from 400 rpm to 1000rpm at idle. It only does this when the car gets warm. The car has been tuned and they say that its not in the tuning. I also have checked for vaccum leaks and have none, I have even bled the coolant system to see if I had any air in there. Car still runs fine but feels like it almost wants to die when warm and idling. Any suggestions would be great. Thanks
Old Apr 21, 2006 | 04:43 AM
b18c turbo civic's Avatar
Default RE: problem with idle when engine is warm help!
realy dont know but ill just **** in the wind and say maby it got something to do whit the backbrecha from the turbo?!
Old Apr 21, 2006 | 08:10 AM
riceburner700's Avatar
have you checked your injectors to see if they are working 100%? also have you done a tune up latly?
Old Apr 21, 2006 | 11:11 AM
I flowed the injectors and cleaned them when I put them in, but they over flow the tubes and I had to shut the machine off before it finished a whole cycle. As far as a tune up i've just recently changed everything. I thought maybe my injecters were not flowing even. But I don't know if it would cause my problem.
00Si_Bennett
Apr 25, 2010 08:04 PM
SPACEGUY18
Nov 20, 2009 02:01 PM
scottdh20
15
Feb 1, 2008 04:43 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
