seafoam engine cleaner???
Old Feb 17, 2010 | 09:43 AM
  #21
4bangersurprize's Avatar
I have use seafoam in many defferent motors with no harm done.
i have used it in rotary application. i would let a vacuum line suck it up tell the motor just about dies. i'm not sure if that would work for a honda though.
Talk about a smoke show. the fire department showed up.....weres the fire
Old Feb 22, 2010 | 05:26 PM
  #22
Junkmanjim's Avatar
I had a Corolla that wouldn't pass emissions. I used Seafoam in the tank and vacuum, then drove it hard for about 75 miles. I went from being just below passing to well into the passing zone. The tester actually is the one who recommended trying and he was surprised at the improvement. I was skeptical because most car additives are snake oil but in this case it appears to have done the job. I made no other modifications other than the Seafoam, might be just some blind luck but if anyone is off a little on passing emissions with an old car, it is worth a shot.
Old Feb 23, 2010 | 08:35 PM
  #23
skat3h3ll's Avatar
this topic just made me want to seafoam my car. Ive used seafoam before, last time was on my eclipse with 112xxx miles, i was worried about using it on my civic since it has 240xxx miles haha.
But now im not nearly as worried. pretty much I just need to change my oil not too long after and i should be all good to go!
Old Mar 1, 2010 | 11:51 AM
  #24
HeyMelo27's Avatar
I take my time when sucking it thru the vacuum hose. It takes a long time for me to suck up all the fluid (1/3 of a can). should i be so paranoid...or can I just let it suck up freely? i dont want it to hydrolock!
Old Mar 2, 2010 | 09:44 AM
  #25
Yes just let it do all the sucking...
I think you will be fine, just make sure you keep the RPM's up, and be ready for a lot of smoke
Old Mar 4, 2010 | 03:24 PM
  #26
enigma34's Avatar
where is the vacuum hose? and do i need to change oil after running it throu vacuum hose?
When i use this i just poor the whole can in a full tank of gas. I want to suck it thro the vacuum hose so i can see how much smoke will come out of my hx which has 233k miles.
Old Mar 4, 2010 | 04:10 PM
  #27
supersize's Avatar
Sir Banned-a-lot
1. idk
2. no, not unless u put it in ur crank case
3. no, 1/3 of the bottle
Old Mar 4, 2010 | 04:34 PM
  #28
Superfly's Avatar
Where do you get seafoam? Just from autozone or somewhere like that?
Old Mar 4, 2010 | 08:54 PM
  #29
supersize's Avatar
Sir Banned-a-lot
yeah, any auto store should have it
Old Mar 5, 2010 | 07:26 AM
  #30
HeyMelo27's Avatar
im just wondering....can Seafoam Deep Creep be used in the same manner as the liquid? i know you can spray it into the intake to clean....but im wondering if you could spray it into the vacuum hose to achieve the same effect. i figure the spray would be easier to apply and spread to "all cylinders evenly"
