SWAPPED ECU AND HAVE O2 SENSOR PROBLEM
Old Jul 15, 2006 | 03:27 AM
92CIVICHB's Avatar
Default SWAPPED ECU AND HAVE O2 SENSOR PROBLEM
I OWN A D15Z1 ENGINE AND I UPGRADED MY ECU WITH AN EX, D16Z6 ECU. CAR RUNS OK BUT I HAVE THE CHECK ENGINE LIGHT ON. CHECKED THE TROUBLESHOOT AND ITS A PROBLEM WITH MY HEATED O2 SENSOR. CAR HESITATES SOMEWHAT. CHECKED THE WIRING DIAGRAMS BETWEEN BOTH MODELS, D15Z1(VX) AND D16Z6(EX) AND THEY ARE WIRED DIFFERENTLY. IS THERE A WAY TO CORRECT THIS PROBLEM. MOVES PINS, ETC....
ANY HELP WOULD BE GREATLY APPRECIATED. THANKS
Old Jul 18, 2006 | 09:43 PM
nikozai's Avatar
Default RE: SWAPPED ECU AND HAVE O2 SENSOR PROBLEM
The z1 (vx) ECU's use a 5-wire Oxygen sensor.
The P28 computer you just installed uses a 4-wire heated O2 Sensor.
You'll need to change to this type: http://rywire.com/store/denso-4wire-...nsor-p-60.html
Old Jul 18, 2006 | 11:30 PM
92CIVICHB's Avatar
I CURRENTLY HAVE A 4 WIRE O2 SENSOR. WILL ANY 4 WIRE O2 SENSOR WORK OR DOES IT HAVE TO BE THE DENSO ONE THAT YOU REFERRED ME TO??
Old Jul 19, 2006 | 07:28 AM
stylincompact's Avatar
what about the secondary o2 how did you get that on?
Old Jul 20, 2006 | 01:43 AM
92CIVICHB's Avatar
I ONLY HAVE ONE O2 IN MY SYSTEM--1992
Old Jul 21, 2006 | 07:53 PM
Mr Mobsta Man's Avatar
CAPS LOCK MAKES ME HOT!!!
sry.
Old Jul 21, 2006 | 09:46 PM
92CIVICHB's Avatar
PLEASE EXCUSE IF IT OFFENDS ANYONE. I ALWAYS USE CAPS. IT JUST LOOKS CLEANER
93HONDA$$civic
Jul 5, 2011 03:20 AM
AuroraEP3
Apr 10, 2009 09:48 PM
branx
Mar 24, 2008 04:32 PM
Fishbulb
Apr 14, 2007 04:07 PM
Fishey
Aug 25, 2006 12:50 PM
