Swapping OBD's
Old May 14, 2006 | 10:57 AM
F23AccordLX's Avatar
Default Swapping OBD's
I am going to put a D16Z6 in my 97' Civic EX and i want to know if i use my intake manifold, alternator, dizzy, etc and i use a conversion harness and a p28 ECU will everything be good? I know that the D16Y8 has a crankshaft fluctuation sensor built into the timing cover and can i just simply unplug that sensor and not pop any engine codes.
Old May 14, 2006 | 01:33 PM
Marty's Avatar
Default RE: Swapping OBD's
It should be a direct swap if you use a conversion harness and a p28, Plugging the crank sensor in or leaving it unplugged will not matter as the P28 will not look for nor will it doing anything with the readings from the sensor.
BcBaudoux
Mar 20, 2010 12:57 PM
JosephAdam22
Jul 24, 2008 05:38 AM
SoCaL.rider
37
Nov 26, 2007 10:28 AM
ineedmoney
Feb 19, 2007 09:22 AM
WHISP63
Oct 24, 2006 11:04 AM
