Tuning for compression?
Old Apr 28, 2006 | 08:09 AM
mentaldis0rder's Avatar
Default Tuning for compression?
How exactly is compression changed.. is this done simply by change fuel mapping? if so would this Apexi unit AFC SELECT be a good option for OBD2 tuning for cost?
Old Apr 28, 2006 | 08:26 AM
sacicons's Avatar
Default RE: Tuning for compression?
to change compression, you have to change the cylinder volume. you can really only do it mechanically. lower it by using a thicker headgasket, raise it by using a thinner one, milling the head (taking the head off and cutting a few thousanths of an inch off of the mating surface, making the domes in the head lower volume, which will raise compression, or a few other things like valves that take up a little more room or high compression pistons.
Old Apr 28, 2006 | 08:44 AM
all that will be done while the block/head are being rebuilt .. so whoever is doing the build i just tell them what i want my compression basically?..guessing from what i read on the Y8 buildup.. 11:0:1 would be a good compression to go with or even 10:5:1 ?? any for sure suggestions
Old Apr 28, 2006 | 11:39 AM
Marty's Avatar
Basicly you buy the pistons for what compression you want. Head and head gasket combos can change compression also but rarely more than a full point
Old Apr 29, 2006 | 05:09 PM
Ok.. so looking at the 75.5 pistons for my Y7 block and slapping a rebuilt Y8 head (ported/polished) 3 angle valve job.. with I/H/E and say Skunk2 68mm TB/Intake manifold..ARP head studs.. (sleeving only if needed) While im having head done i may get crower stage 2 NA cam with springs/lifters..do u think i need a metal head gasket?????? also what ECU would work for tuning that is cheap for OBD2.. ie 96 civic.. hondata work for this app?
Old Apr 29, 2006 | 07:54 PM
jwsimons's Avatar
obd2 is not tunable... convert to obd1 (actualy i may be incorrect, i know that only obd1 , for turbo.. and all program are written for obd1.. so im 90% that you cannot tune an obd2... and 99.9% that you cannot tune an obd2b... ... convert, young man, convert and be saved!!! haleluya
Old Apr 29, 2006 | 08:31 PM
sacicons's Avatar
you can tune OBD2, just not chip the ECU. a piggyback will work fine, and Hondata is a great setup, but wont work with OBD2 civic systems. but you can do a simple V-afc that will get the job done. though I would still look into converting to OBD1 since it is easier to tune, and you wont get as many check engine lights.
Old Apr 29, 2006 | 08:33 PM
i have emissions inspections.. obd1 conversion will fail me.. and will the afc unit i have listed above work then?
chones2083
Jun 2, 2005 06:48 PM
nachoman
May 23, 2005 02:37 PM
aquessada
Feb 21, 2005 03:00 PM
Dickie
Feb 10, 2005 06:24 PM
Blackhatch124
Nov 10, 2004 08:20 PM
