vafc
Old Aug 1, 2007 | 01:01 PM
nik005's Avatar
Default vafc
is it possible to run a vafc to get ur turbo car to run the right air fuel ratio on stock injectors or is it necessary to get bigger injectors
Old Aug 1, 2007 | 04:58 PM
gsumano's Avatar
Default RE: vafc
yes, you can used the vafc to run a turbo but you still need bigger injectors!!!. What year of car do you have?Unless you live in CA, i will just run a chipped ECU.
check this link if you're still interested in running the afc hack.
http://turbod16.com/viewtopic.php?f=7&t=2118
Old Aug 9, 2007 | 04:37 PM
MY99SI's Avatar
Default RE: vafc
get a minimum of 450's or 390's. if you try to use stock injectors.. it will blow up
Old Aug 9, 2007 | 05:05 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default RE: vafc
dont use the vafc, get a chipped p28 and dsm 450s and run that instead.
Old Aug 9, 2007 | 05:31 PM
polo708's Avatar
Default RE: vafc
Injectors will only flow a set amount of fuel based on its size, so if you are running alot of boost and allowing more air in than the injectors can flow fuel to match you will run lean and damage your engine quick and easy. Also, injectors arent supposed to be pushed over about 85% of their max flow capability since it could cause them to inject sparatically.
So, short answer: depends on the amount of air you are flowing. 9 times out of 10 you will need larger injectors for a turbo setup.
FastFwd
Mar 11, 2006 03:08 AM
jobu03
Nov 10, 2005 11:18 AM
elfreaky70363
Sep 18, 2005 06:56 AM
turboturd98
Aug 15, 2005 11:40 PM
finalimpact
Jun 3, 2005 11:07 AM
