VTEC troubles
Old Oct 2, 2005 | 10:27 AM
Clean98EX's Avatar
Default VTEC troubles
So i'm driving last night and when the VTEC should kick in, all i got was spuddering and it wouldn't rev any higher. Is there a fuse for the VTEC system? I tried to look in my Chilton manual, but they had nothing for the VTEC system at all. So any ideas or advice would be great!!!
Old Oct 2, 2005 | 11:47 AM
Street Sniper's Avatar
Default RE: VTEC troubles
Bad solenoid?
Old Oct 3, 2005 | 03:57 PM
Clean98EX's Avatar
Well, don't know what it was but this morning it worked fine!!!!!!! Must have been a fluke? But all is well and the VTEC is pulling hard!!!
Old Oct 7, 2005 | 03:01 PM
dj_ipirate's Avatar
maybe that vtec controler you installed is damaging something. lets hope not cause i want one too.
Old Oct 18, 2005 | 04:51 PM
TheBlackCivic's Avatar
Im new here, but I registered simply to get on this thread, im having similar symptoms with my civic ex. Like the dam things got a cold, vtec works fine one moment but the idle is screwy and starts poorly, drive it home shut it off restart and it will start better, but have no vtec it gets to vtec point and sputters. Im told this is because of an ecu? Anybody else have something like this? im running an all motor setup. Could the stock ecu be unable to handle the motors parameters now?
Old Oct 18, 2005 | 09:44 PM
mill$civic's Avatar
im not a expert at this or anything, but could it be when adding somthing new you didn't reset your ecu and thats making the v-tec screwy?
Old Oct 19, 2005 | 04:53 PM
Are there any check engine codes showing up on yr car? mines showing three P0113 Intake air temperature circuit low input, p1508 Idle speed control system low, and p1259 Vtec system malfunction in the rear bank? Anyone know what causes these codes? i thought my ecu was bad because im running a built motor. Yes to the other new guys sinquiry i did reset the ecu after the mods were done. no difference.
Old Nov 8, 2005 | 09:39 AM
lostgen's Avatar
you may want to check your filters, if you have an intake system that may be your low speed sensor problem and with the air sensor, also inside your engine deep with the beast where the vtec originates there lies a filter for the vtec, you may want to check that and replace it, anyways good luck with solving the issue if u havent solved it already.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
mpilic
EG Swaps
12
Nov 9, 2005 02:04 PM
WhiteCiv2000
Oct 11, 2005 10:16 PM
ItsBobtista
Jun 18, 2005 10:27 PM
Readyforthepasture?
Nov 6, 2004 09:57 AM
