What fuse is for the dash?
Old Jul 18, 2005 | 09:24 PM
93SiHb's Avatar
Default What fuse is for the dash?
having problem with the dash not lighting up which fuse is for the dash since im mising all the fuse cover s including the ngine bay one i checked the engine bay fuses they all work but inside is a diffrent story theres about 5 that wont light up with the test light would i have to switch on the lights then try the fuses some one help
Old Jul 19, 2005 | 07:46 AM
92LxCiViC's Avatar
Default RE: What fuse is for the dash?
replace the dimmer switch. my dash was doing the same and replaced the dimmer and it works fine now.
--James
Old Jul 19, 2005 | 09:12 AM
LEVIII's Avatar
yes to test the fuse with a test light the lights DO have to be on.
Old Jul 19, 2005 | 03:25 PM
93SiHb's Avatar
which fuse would it be levi cuz with the car on about 5 or six fuses dont light up on the test light
Old Jul 20, 2005 | 12:12 AM
93SiHb's Avatar
where can i get the swithc besides ebay and the junkyard
Old Jul 20, 2005 | 12:44 AM
sacicons's Avatar
with a test light, you need to test BOTH sides of the fuse. if one side lights up, and the other side doesnt, then its bad.
Old Jul 24, 2005 | 11:29 AM
93SiHb's Avatar
Fixed got lucky at the junkyard only one civic in there and guess what it had the dimmer switch and it worked fixed the whole dash lighting up problrem works like a charm now also put some new fuses in for kicks
addiction2bass
Aug 1, 2022 06:23 AM
RicerMcGee
Nov 13, 2013 05:39 PM
mrmagic0097
12
Feb 18, 2009 01:45 PM
IMPORTEDCONCEPTZ
Dec 10, 2006 09:46 PM
kennyl_10
Jul 26, 2005 10:07 PM
