what required to get a 2000 cx with no tach to have one?
Old May 15, 2007 | 01:38 PM
basbal123's Avatar
Default what required to get a 2000 cx with no tach to have one?
hey, i have a 2000 cx hatch 5 spd and it has no tach and its startin to **** me off now, im lookin at a 2000 si gauge cluster, but what do i have to do to make it work?
Old May 15, 2007 | 01:42 PM
ej6buddy's Avatar
Default RE: what required to get a 2000 cx with no tach to have one?
this has been covered thousands of times (and that's not an exaggeration), it's all plug and play, just use the search feature first for any questions, if you can't find it, then ask
Old May 15, 2007 | 02:22 PM
Marty's Avatar
96-00 civic ex, lx, si gauge cluster
Old May 15, 2007 | 02:26 PM
basbal123's Avatar
i kno that but my car at the moment has no tach so is it still plug and play? since the si cluster tdoes have a tach
Old May 15, 2007 | 02:31 PM
Marty's Avatar
yes they are all pre wired for a tach, you cluster actually has the tach wire/plu plugged into the back of it but no tach on the front.
Old May 15, 2007 | 03:17 PM
basbal123's Avatar
ok well that makes it easy thanks
Old May 16, 2007 | 05:22 AM
cderalow's Avatar
ORIGINAL: Marty
i didn't think the LX had a tach either
the swap is easy, should take you 30-45 minutes if you swap the speedometer/odometer to retain your accurate mileage.
also, I'd look into the EX cluster, as it'll be cheaper in the long run
Old May 16, 2007 | 08:11 AM
Marty's Avatar
some of the lx's do, it was available as a option
Maboroshi Nezu
Jun 7, 2010 03:31 AM
panaphobic
Mar 13, 2008 01:14 PM
zoso
Jul 28, 2007 01:40 PM
jax00civic
Jul 22, 2006 04:51 PM
dalifts
Dec 16, 2004 10:34 PM
