Odd LS swap questions
Hi all. I have an 88 hatch in the middle of an LS swap and had a few questions.
1. Should I get a half or full aftermarket radiator, keeping in mind I plan on going turbo in the future?
2. What size fuel pump should I upgrade to?
3. Should I use shocks meant for the integra in the front to compensate for the heavier motor?
Thank you.
Thank you.
1.......half size radiator will help once your turbo so id go for it if you can afford it.
2.......walboro 255lph is more than enough for most applications
3.......no, spring rates if you really want to......and integra shocks are longer therefore raising your front end up.
solewheelin
Jul 7, 2006 07:18 AM
