odd swap
Old Aug 28, 2009 | 08:06 PM
oldskoolfool's Avatar
Default odd swap
so i have a bit of an old schooler...... a '90 dx.... not real old i know but still. the question is - it has a 1.5 that hasnt ran in a few years and i was wonderin if anyone had any knowledge at all of how difficult a b series swap would be into this year??? would i have to change out EVERYTHING i dont have a lot of access to much equipment so keep that in mind for me.......
thanks,
noob
Old Aug 28, 2009 | 08:13 PM
to swap the engine it will need alot of work. you gotta rewire the ecu and convert your engine from the dual point to mpfi. first. then you need a pm6 ecu(from 88-91civic si),b' series complete motor and trans. custom motor mounts, cv axles , front rotors and calipers all from the integra.
Old Aug 29, 2009 | 04:45 AM
T-flow cylinder heads's Avatar
This is something that im try to do aswell. I have 89 civic DX and trying to figure out whats the best route. B,H,F series? And yes I understand that other stuff will be neded. Looking for all parts needed for this swap, any info would be greatly appreciated. Thanks, T-flow cylinder heads
Old Aug 29, 2009 | 06:50 AM
well first you gotta get rid of the dual point and convert to mpfi and get a ecu from a 88-91 civic or crx si the ecu is pm6 and the resistor box.
heres my 91 civic when i converted from the dual point to mpfi
then you can go for a b' series engine. try to get one from a older model integra one that is obd0 just like your civic's you can get new but will be alot more wiring involved.and you wont have to convert your clutch from cable to hydro.
to swap in the b engine you will need
complete b engine and trans
cv axles from the b' engine
the front rotor complete assembly
custom motor mount from like hasport.
Old Aug 29, 2009 | 04:54 PM
Thanks, how much more work is involved in a K swap?
Thanks, Todd @T-flow cylinder heads
Old Aug 29, 2009 | 07:35 PM
alot of $$$$$$$
just the motor and trans alone is very expensive.
Old Sep 2, 2009 | 07:14 PM
ok so no b series....... its a d15 sohc. so, if i place a d16 vtech head will that frankenstein work? like bolt right up?
Old Sep 2, 2009 | 08:55 PM
PunisherInOKC's Avatar
Yes and no.
You can go ahead and put on the VTEC head, and the car will work just fine. Kicker is - no vtec power.
You have to hook up the vtec solenoid and get the vtec ecu - which I believe is OBD-1. < someone correct me if wrong. Its been a while. =P > If its OBD-1, you gotta change wiring. Fun stuff. Also, still have to change DPFI to MPFI.
All of this sounds kinda hard, but its not that bad.Just get a few buddies over, and take a weekend to get R done.
Old Sep 2, 2009 | 11:40 PM
ugli's Avatar
if i recall correctly that's called a mini-me set-up
do a google search for d15b2 mini-me for a lot of info on it(or check this site, i just started reading about it and haven't looked on here yet)
Old Sep 3, 2009 | 07:04 PM
ok do i didnt think that through very much..... it was kinda obvoius after a lil consideration. so let me try again, im thinkin a d16 head might be easier to place than a d15, so if i find a d16 sohc head before i can find d15 should i go ahead get it? can i bolt a normal d16 head on that d15 block and plug all the injectors and crap right in no prob? im really ready to get this back on the road
kimsuprapa
ED-EF Swaps
Oct 9, 2006 01:50 PM
solewheelin
Jul 7, 2006 07:18 AM
ufotruth
May 22, 2005 08:10 PM
Forty04
17
Apr 29, 2005 03:33 PM
Forty04
Apr 27, 2005 07:31 AM
