ED-EF Swaps 1991 and older Civics, CRXs
swap into a 1988 civic....b16a1/b18c hybrid with dual carb????
Old Jul 16, 2007 | 09:59 PM
ranom01's Avatar
Default RE: swap into a 1988 civic
sweet as is there anything else i need to get
Old Aug 1, 2007 | 01:53 AM
ranom01's Avatar
hi agian, i just brought a b16a1 engine and im goin to rebuild it with a b18c head and a turbo, but my car started with a carb rather than injectors so can i make a custom intake that will take the dual carbs off the d15b engine and still hav the turbo???
Old Jan 29, 2008 | 11:08 AM
jamned's Avatar
Dang, this is an old post. Still, I'll comment on what I know.
I have an '87 civic with a D15A2, which is carbureted. I thought about doing a swap to convert it to FI civic. I realized that this job would require more than just swapping the engine, adding an ECU and wiring, and a fuel rail to run. For one thing, my D15A2 has a mechanical fuel pump, which feeds directly off the camshaft/distributor. I'd have to install an electric fuel pump on top of the gas tank. I haven't checked how my gas tank looks--it might be compatible with an electric gas pump. If not, then I'll need to drop the fuel tank and put in one from a fuel injected car. I'm pretty sure I'd have to replace the existing fuel lines as they probably weren't made to withstand the high fuel pressures typical with fuel injection. This would include the fuel lines running from the gas tank to the engine bay!!!
To answer your question, ranom (in case you haven't found out already, and for others who might be wondering), you can make a turbo carbureted car. You're going to have to make modifications to the carburetor or get a new one, as it has limited size fuel jets. At higher rpms, you'd be sending a lot more air into the engine than fuel (running lean), which would be very bad.
A critical step in turbo installations is tuning your car so that your air/fuel mixture remains in a relatively safe region. From what I understand, this is typically slightly richer than stoichiometric (stoichiometric is a perfect match of air/fuel for 100% burn). You want this type of mixture because stoichiometric burn would be too hot for the materials in the engine, burning the valves and possibly causing head gasket damage (I'm not sure what else happens as a result of overheating). A slightly rich mixture leaves a small amount of fuel unburned to absorb heat and send it out the exhaust. Tuning a FI car means running it on a dyno and adjusting the ECU settings. Tuning a carbureted car means changing the carburetor fuel jet sizes to provide the right mixtures of fuel at different RPMS...I'm not sure entirely how you go about doing this. Changing the fuel jets means taking apart the carburetor, though.
Old Aug 24, 2014 | 01:49 PM
DannyH22's Avatar
I'm looking to swap a B18B engine in my 88 civic what do I have to do ??
GreenGoanna
Oct 11, 2011 09:01 PM
keithm416
Sep 20, 2010 01:56 AM
raf300
Feb 26, 2010 04:40 AM
ranom01
Jul 12, 2007 09:59 AM
315 Customs
ED-EF Swaps
Jun 9, 2005 06:43 AM
