Frankenstein
Umm yes.. you can.. but theres is no SOHC 1.8 or 20... they are B18's and B20's witch are DOHC.. Its an ls-vtec when you do it.. you can get good power.. but for the enigne lasting not so good, dependability is an on going issue..
I thought the Frankenstein swap was taking the b20 engine and swaping on the head from a b16 that way you get the 2.0 (hence the b20) but the vtec head from the b16 (which is a dohc 1.6)... then again i could be wrong but that was my impression of it
sohc heads only work on sohc blocks, dohc with dohc etc. you can take a non vtec d series sohc block and put a d series vtec head on it to make it vtec (with additional wiring etc) its called a mini-me. or you can take a b series non vtec block and mate it to a b sireies vtec head and it is called a frankenstien
