EG Swaps 1992-1995 Civics
i'm a newbie to swaps
Old Mar 27, 2005 | 08:57 PM
mtchbookromnce18's Avatar
Default i'm a newbie to swaps
ok... i have a 93 honda civic dx with a d15b7... but... it has a bent valve. i honestly just want to drive it to get around. how much would i be looking at to find an exact swap. or should i look for something a little better? i'm not sure what i should look for exactly. i have very limited funds right now since i'm in school. any help would be great
Old Mar 27, 2005 | 10:55 PM
se7ensectoolate's Avatar
Default RE: i'm a newbie to swaps
ORIGINAL: mtchbookromnce18
A friend of mine has a D15 motor that's free. Only problem is that it's in St. Louis.
Old Apr 2, 2005 | 07:07 PM
seanperia's Avatar
if you want a cheap fix just get the engine fixed no need for a swap but if you want a little bit of an upgrade you can put almost any d-series engine or b-series engine in your car you just have to look around for a good price. hope this helps.
Old Apr 4, 2005 | 12:25 AM
finalimpact's Avatar
less than $400 at a local shop and your car should be back on the road. id personally just either replace the valve or replace the head as its quick, easy, and a whole lot cheaper. save up money do some research and find out what you really want to swap into your car.
Old Apr 24, 2005 | 08:13 AM
SoCal_EG5's Avatar
Default It's on you. mtchbookromnce18
Swapping an engine can be expensive and at the same time cheap that is if you know what you are doing. I used to have a D16 SOHC (Single Over Head Cam) motor as a stock engine when I first brought my '95 Civic EX. 'D' series isn't bad at all. It can be very powerful with some mods and like I sad before if you know what you are doing it can be very cheap. Even though it's not like having a DOHC (Dual Over Head Cam) 'B' series motor. Which is alittle more power stock than a 'D' series.
I'm on my fourth motor now due to major mechanical knowledge. But I learn more and more by just working on it. It save my some money as well.
Go on ebay and search around or go to
http://www.passwordjdm.com/
http://www.hmotorsonline.com/shop/
http://www.totaljdm.com/index.cfm
http://www.sunrisejdmmotors.com/index.php
http://www.nippon-motors.com/index.htm
http://www.ardperformance.com/
http://www.hondahookup.com/
StealthFox
Mar 24, 2005 03:59 PM
JW2501
Mar 21, 2005 09:56 PM
pkfrdh
Mar 18, 2005 04:11 PM
IRVILLEracin98CIVIC
EK Swaps
Aug 9, 2004 07:50 PM
IRVILLEracin98CIVIC
Aug 3, 2004 04:58 AM
