EG Swaps 1992-1995 Civics
Swas recomendations URGENT
Old Jun 20, 2006 | 09:56 PM
HaZe89's Avatar
Default Swas recomendations URGENT
I have a 95 honda civic ex coupe, 1.6L vtec soch. i was thinkin to swap the engine. My questions is..... what engine would perfectly fit my car without any modifications on the mounts???Other thing i was thinkin is what should i do with my car??. It has 173.000 mileage , it is invery good conditions (exteriors, interiors) should i get rid of this high mileage car or pimp it up? i mean it has been used very much and it may cause further problems with the engine and other mechanic stuff. would an engine swap solve this problem
Old Jun 21, 2006 | 02:06 PM
HaZe89's Avatar
Default RE: Swas recomendations URGENT
i have a 95 honda civic ex coupe, with a D16Z6 engine 125 hp it has 173000 mileage and i was thinking in to swap it for a newer one si i was thinkin on the following : b16a b18c b17a h22a b18c5 which of this will fit my car perfectly without making any or minimal modifications??????? which is easy to find?????????
Old Jun 21, 2006 | 03:58 PM
ef4life's Avatar
all those b series engines will require the same amount of modification. you will need a mount kit and stuff but no fabrication is needed. the h22 is a litle different and should not be attempted by the faint of heart because it takes a little skill and know how to make it work and make it look good,
Old Jun 21, 2006 | 05:20 PM
HaZe89's Avatar
Thanks ill better forgwet about the h22. but now witch of the B has the more power you know more HP, vtec, twincam .. and which will be easier to find
Old Jun 21, 2006 | 09:13 PM
ef4life's Avatar
b18c5 - 195hp - us integra type r - about 5000
b18c - 197hp - jdm integra type r - about 5000
b18c1 - 170hp - us integra gsr 3rd gen- about 3000
b17a - 170hp? - us integra gsr 2nd gen - ???
b16a - 160hp - us civic si, del sol vtec, various jdm civics - 1000-2500
the higher the hp the harder they are to find.
Old Jun 22, 2006 | 01:25 PM
finalimpact's Avatar
actually no swap kit is needed in an eg........use 94+ integra factory mounts and **** linkage with a b swap and your good to go. this is only to get the engine in the car.........some wiring will be involved if your using a vtec engine.
Old Jul 1, 2006 | 02:07 AM
civicracer94's Avatar
ORIGINAL: ef4life
b18c1 180hp
b17a 160hp
Old Jul 23, 2006 | 12:05 AM
killajay's Avatar
I dont know about mount kits.. my B18B1 fit in my 92 DX HB with the stock motor mounts with out any mods to it..
Old Jul 27, 2006 | 04:39 PM
deucedeuce's Avatar
Get the H22. It's mean as h***!
ElQueTeniaQueLlegar
Jul 21, 2007 04:26 PM
HaZe89
Jul 31, 2006 10:00 AM
addiction2bass
Jul 14, 2006 06:01 PM
FlipHKD720
Jul 12, 2006 12:43 PM
HaZe89
Jun 23, 2006 03:29 PM
