98 Hx Swap
you need an SI mount bracket. this bolts on to the block. use your stock liquid filled mount.
and the SI rear transmission bracket. you can't use the one that will come w/ the swap. it's different.
the a/c mount you can use that will come w/ the swap, but if you are planning to run an a/c, you will need to get a p54 a/c bracket
you will also need to wire vtec, and knock sensor.
