EK Swaps 1996-2000 Civics
B18C Fuel mileage?
Old Jun 11, 2006 | 11:20 PM
pWnEdU's Avatar
Default B18C Fuel mileage?
I'm curiouse, for those of you who have done the B18C swap, what kind of fuel mileage have you been getting?
Do you keep your stock 5 speed or is a different one used? If you use a different one, is the final drive ratio different (like the Si that turns more rpm's on the highway) or is it the same ratio as our tranny's?
Also, will your I/H/E change over to the new engine or is all new needed?
Old Jun 12, 2006 | 01:11 AM
bebeh's Avatar
Default RE: B18C Fuel mileage?
i asked the same question and this is what saccions answered for me
some are interchangeable, but some will give you problems, like the manifold on a gsr motor sits lower and most intakes wont fit, it has to be a gsr intake. and most SRI will fit a d or b series. header will be different though. except the gsr, most 92+ civics use the 99-00 si intake just fine with a swap
Old Jun 12, 2006 | 10:25 AM
pWnEdU's Avatar
Ok, so then it sounds like most everything would have to be changed, thanks man.
So now about the final drive ratios and tranny compatibility? And fuel mileage?
legal
Jan 26, 2008 09:35 PM
sick4civic
Dec 2, 2007 09:31 PM
cowsgonemadd3
Sep 1, 2006 10:08 PM
FlipHKD720
May 24, 2006 08:24 PM
Esquirrel
55
Feb 6, 2006 04:18 PM
