Uhhhh, need some moral support
AAAHhhhhh!!! Some I am getting ready to do a B16A2 swap with an OBD1 motor into my 2000 EX. Well I am starting to get a little leary about whether or not to attempt this myself. I have never done anything this mechanical before, I do electrical and do it well!! But my motor in the vehicle is blown and I really don't have a choice but to replace it. I just need some feed back about how hard this swap is. Oh and here is the list for what I have towards the swap already if I am missing anything let me know!!!
1. B16A2
2. LS Hydro Tranny
3. Exedy Stage1 clutch for B16
4. Exedy Flywheel
5. Autozone 99-00 SI axles
6. OBD2B to OBD1 ECU adapter
7. AEM Fuel Rail
8. AEM Fuel pressure Reg
9. Walbro Fuel Pump
10. AEM Timing Gears
11. B-series shift linkage
12. DC short shifter
So am I missing anything or should I just starting ripping bits out and putting em back in????
Oh and also a haynes manual for more technical guidance. The only reason I'm considering doing it myself is for the fact that my local speed shop wants a grand for it. Which isn't that bad, but still its a thousand dollars!!! Thinks of the Cams you can get with that!!! Hell maybe even valves!!
1. B16A2
2. LS Hydro Tranny
4. Exedy Flywheel
7. AEM Fuel Rail
9. Walbro Fuel Pump
well no one came up with anything additional so allow me to make a list off of the top of my head as of now what did not fit.
1: Throttle cable ( * knew this one and forgot all about it!!)
2: A/C Compressor and lines, yeah wasn't very happy about that one. I know some don't care but I do
3: Power steering pump lines,
4: Coolant hoses weren't long enough
5: Intermediate shaft ( had never before heard of this thing, so this was a good learning experience)
6: Intake is still yet TBA
7: If you are doing a J- spec swap make sue you get the full F'n wiring harness!!!!! I didn't and I ended up having to pay through the rear to splice the obd2b harness to the obd1 j-spec on the motor, I figured I needed more but man I didn't know how much. I would say all together I am about an additional $1000 dollars in than what I had origanally expected. So with everything I am about $5K deep in this freakin project, still not Emissions compliant and dead broke.
Man, I did a whole bunch of research, saved my pennies, and still managed to not get what I expected. The only thing I hope is that by the time all this is done that my car will at least still get good gas mileage.!!!!!!
ORIGINAL: sillyredcivic
Trevler
Nov 14, 2014 05:06 PM
