EK Swaps 1996-2000 Civics
Cheapest way to get to 200hp
Old Aug 23, 2006 | 12:06 AM
Mr Mobsta Man's Avatar
Default Cheapest way to get to 200hp
I have a 97 ex [d16y8] with 151k miles on it. I want to know if it would be cheaper to rebuild the internals and turbo it to 200hp or just do an h22a swap with stiffer shocks to counter some of the weight problems it would cause. Also keep in mind I have to pay labor for the swap or internal work. Thanks to anyone that can help!
Old Aug 23, 2006 | 08:26 AM
Fiasco's Avatar
Default RE: Cheapest way to get to 200hp
the internals and turbo imo. Really it depends on how good of a deal you can get on the swap.
You can do what im doing if youre patient enough and that is finish all the internals now and enjoy the results while you piece together a kit ala Petes Grocery List. 100 bucks every 4 weeks and im already up to having the manifold, bov, downpipe, and oil feed. Just a thought.
Good luck!
Old Aug 23, 2006 | 10:17 AM
96civic285whp's Avatar
Probly to turbo the d-series. Here are a couple of web sites to look into if you want the h22a. It has a lot of hidden costs, mounts, axles ect. www.JDM****.com, and www.HASport.com.
Old Aug 23, 2006 | 03:34 PM
After I get the internals upgraded, what do you think would be the highests psi I could run safely and what hp could I get from it?
Old Aug 23, 2006 | 04:04 PM
I'd say 15-20psi , and close to 300whp if you go forged, 15 psi and a good tune could net you in the 200-250 range. If it was me i would turbo what i have and run 6-7psi till it gave up then upgrade. 6-7 psi should get you close to 200hp at the flywheel.
Old Aug 23, 2006 | 04:27 PM
Could you give me a link to somewhere that has a list of that needs upgraded or could you tell me?
Old Aug 23, 2006 | 04:38 PM
ef4life's Avatar
there was a link to jeff evans tuning, he has a completely internally stock d16z6 and is pushing 375whp so 200 is very possible on a stock engine there are a lot of people doing it, the secret is in the tuning
Old Aug 23, 2006 | 05:37 PM
http://www.evans-tuning.com/
Old Aug 24, 2006 | 04:30 PM
AllForSRT's Avatar
http://turbod16.no-ip.com/index.php?...fc7f4f21bf2dab
best site barnone.
Old Aug 24, 2006 | 09:00 PM
I cant load that site, I keep getting an error
bank5
Jun 29, 2017 06:01 PM
SI fanatic
Jul 17, 2008 10:36 AM
deadphishy
Feb 4, 2006 06:14 PM
brokenarmboy19
Sep 21, 2005 04:39 PM
GWhiz
Jul 3, 2004 11:00 AM
