EK Swaps 1996-2000 Civics
Planning to swap a B18C1
Old Apr 28, 2007 | 10:56 AM
asttak's Avatar
Default RE: Planning to swap a B18C1
It's a 97 GSR that should be OBDIIthen.
Old Apr 28, 2007 | 06:34 PM
mxs's Avatar
mxs
Most of the info you need can be found here: http://kosmo.homedns.org/trey/6gen/
Old May 2, 2007 | 01:36 AM
asttak's Avatar
Alright after doing all my research I've gathered all the stuff I hope I need. I thought my buddy knew a lot but I guess he really didn't know too much except for, "YEAH IT WILL FIT".
LIST:
Complete 97 GSR engine
2000 civic si cluster
GSR Axles
GSR Shift Linkage
GSR ECU (OBDII)
GSRDriver and Transmission mounts (does it need to be the si ones or will the GSR ones work just fine?)
(I don't need AC!! WINDOWS FTMFW!!!! Just hope stop lights are green at all times lol)
1. Now for my other concerns, for my catback system, I am not using my OEM 96 cat converter but using a megan racing resonator or test pipe. Will I need to use the GSR's Cat Converter?
2. Wiring Harness... I am still confuse about this part.
Again I'll be dropping this badboy into my 96 EX coupe.
Thanks in advance.
Old May 4, 2007 | 12:58 AM
ivtec's Avatar
ORIGINAL: asttak
LIST:
GSR Axles
GSR Shift Linkage
GSR ECU (OBDII)
Thanks in advance.
Everything looksreadyto goto me, I used Si mounts since I did a B16 swap but the GSR ones should fit just fine as well, unless someone did a B18C1 swap before and knows.
For my catback system I just used the B16 cat converter and it bolted right up to my EX catback. Don't know if this will be the same for a B18C1.
And the wiring that my uncle did for me lol, so I can't really answer that from personal experience.
Hope this helps GL on your swap.
vmf
Mar 10, 2008 10:11 AM
ivtec
May 5, 2007 02:22 PM
mill$civic
Jan 4, 2007 01:00 AM
1uk3m4n
Nov 27, 2006 07:27 PM
Crook_EG8
May 12, 2006 07:06 AM
